Configures BPDU Restrict.
| stpd_name | Specifies an STPD name on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| bpdu-restrict | Disables port as soon as a BPDU is received. |
| recovery-timeout | Time after which the port will be re-enabled. |
| seconds | Specifies the time in seconds. The range is 60 to 600. The default is 300. |
The default is disabled.
Before using this command, the port(s) should be configured for edge-safeguard.
The following command enables bpdu-restrict on port 2 of STPD s1:
configure stpd s1 ports bpdu-restrict enable 2
This command was first available in ExtremeXOS 12.4.
